Discussion topic: sky and using vpn
Message posted on 15 Aug 2025 08:10 PM
sky and using vpn
Hi folks
Am thinking of getting a VPN service and I believe the sky router does not support this, but a IT guy says I would need to get a new router for it to work properly
I am just wanting to check that there is nothing in the t&c about this. ie is it allowed?
thanks for any info
Message posted on 15 Aug 2025 08:25 PM
Re: sky and using vpn
There isn't any model of Sky Hub which can itself host a VPN service. It's entirely legitimate to use VPN client software on devices behind a Hub.
Message posted on 15 Aug 2025 08:39 PM
@troonguy1 Your IT guy may have been suggesting a different router/hub that supports applying a VPN for all devices connected through the sky, that is an option that the HUB does not support, but buy the VPN that can be used on multiple devices and apply it all you wish to vpn on!
Message posted on 15 Aug 2025 08:54 PM
I beleive he was going to use the new router hub to install the vpn into (AdGuard), rahter than use a service like Nord, where you download their app
thanks
Message posted on 15 Aug 2025 08:57 PM
Sky doesn't block use of non-Sky routers, but it won't offer help with them either and some just won't work.
There's also no way to have Sky Talk Internet Calls without a Sky Hub.
Message posted on 15 Aug 2025 10:34 PM
yeah, he just said that my calls wont work and would have to get a voip box to make it work. Does sky offer this, do you know?
thanks
Message posted on 15 Aug 2025 10:50 PM
@troonguy1 No is the answer to that!
Message posted on 15 Aug 2025 10:55 PM
thanks for all your replies
