Discussion topic: sip alg
This message was authored by: JoeJune
sip alg
Hi,
Hope someone can advise, I need sip alg removed from my router. For voip phone.
I have tried without sucess. Any help please?
This message was authored by: Jonny321
Re: sip alg
I have the same issue.
It appears the setting to disable SIP ALG is no longer and option with the Sky Max Hubs.
This message was authored by: The_Stelfox
Re: sip alg
Go into Advance, click on Port Triggering, Click Enable, your problem should be sorted.
