Discussion topic: signal
Message posted on 05 Dec 2024 06:10 PM
signal
can i use a hdmi transmit/recevier from sky box to tv without cable running through room to room
Message posted on 05 Dec 2024 06:14 PM - last edited: 05 Dec 2024 06:18 PM
Re: signal
That's not a broadband issue (or even related to ISP WiFi)
Such devices exist but are notoriously unreliable, particularly over any distance or through walls.
I'd suggest research online, and only buying from suppliers with a good returns policy.
Message posted on 06 Dec 2024 04:19 AM
Re: signal
Hi
TimmyBGood
the distance between skybox and tv
is no more than 9ft with open space?
Message posted on 06 Dec 2024 07:25 AM
Re: signal
@andrew736 if you buy the kit online you can return it within 14 days if it doesnt work which nobody can predict until you try it. Basically in theory it should work but practice doesnt always follow theory. Cables are far more reliable
Message posted on 06 Dec 2024 07:41 AM - last edited: 06 Dec 2024 07:42 AM
Re: signal
You'll find real world reviews of such devices (rather than marketing guff) where the video stream breaks up whenever a viewer moves. It really isn't great technology (particularly at UHD) otherwise it would be far more widespread, but you may find something which works for you.
Message posted on 06 Dec 2024 05:29 PM
Re: signal
Sorted
worked out what to do
flat hdmi cable running from sky box in dinner to living room to tv under the underlay and carpet
Message posted on 06 Dec 2024 05:47 PM
Re: signal
Just check it works at the resolution you expect before putting it in place ; )
