Discussion topic: setting up broadband
This message was authored by: Marilena09
I am trying to set up the vroadband hub! I followed all the steps but the internet light is not turnung green. There might be a problem with my phone sockets?? can someone come and fix it ? is there anything else i can do?
Re: setting up broadband
@Marilena09 What day is it that you were advised for activating your new sky broadband connection! Are you moving from an already working provider to sky, or is this just a first time new install!
You also have to be connectedd to an OR Master phone socket for the hub to work, and you should say single/dual socket and where you connected etc, electronic link to connecting is below for you!
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
