Discussion topic: Sky hub installed today
Message posted on 18 Jul 2025 09:11 PM
I spoke with someone earlier regarding my hub not connecting. He ran some tests and said it should all be ok within the hour. It isn't. I'm now with out tv and phone line. I transferred over from BT broadband and was assured it would be fine. Obviously not feeling happy about my decision.
Message posted on 18 Jul 2025 09:32 PM
Re: Sky hub installed today
@SG30 It can take up to midnight for your service to go live, if it's not working tomorrow please post back to this thread.
Message posted on 18 Jul 2025 10:54 PM
Similar experience. Activated Skybb today having moved from BT. Nothing but problems - tv cutting out mostly
Regretting leaving BT bb now. Will return
Message posted on 19 Jul 2025 07:16 AM
@Greg1791 You have found that NO two hubs are alike, what you had with BT hub is different from the Sky hub, but it is all your choice what to do! If you do find you need advice you may have to tweak a few setting's on the sky Hub but you for sure need to say which model you got installed!
https://ee.co.uk/help/broadband/getting-started/compare-our-range-of-broadband-hubs
Message posted on 19 Jul 2025 01:35 PM
The white hub and an extender
Message posted on 19 Jul 2025 01:39 PM
Have you had any resolution yet?
Message posted on 19 Jul 2025 01:40 PM
@Greg1791 Since you have just installed a sky Max hub and it's associated extender, you may wish to with your app look at the wireless wi-fi settings in the hub and back them off a bit to the WPA2-PSK mode instead off any WPA3 modes. May help with stability off the devices that are trying to connect!
Message posted on 19 Jul 2025 01:42 PM
Thank you for taking the time and interest to respond. To be honest I'm not sure how to do what you laid out there.
Message posted on 19 Jul 2025 01:44 PM - last edited: 19 Jul 2025 01:47 PM
@Greg1791 See if the help article below is off any good! None off your BT equipment supported any off the new features that are included with the sky Max purchase that you have done!
Connecting older devices to Sky Max or Gigafast+ Hub | Sky Help | Sky.com | Sky Help | Sky.com
