Discussion topic: problem with wifi - keeps clicking off
This message was authored by: clare152
hi we're having a problem with our wifi over the last few days. the signal keeps clicking off - the internet goes down and the tv signal is also disrupted. the box on the wall seems unsteady
Re: problem with wifi - keeps clicking off
@clare152
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This message was authored by: tonydogbite
hi, was this resolved as im having the same issue with my broadband.
@tonydogbite
The OP only posted an hour ago.
Avatar for clare152
wifi disconnecting
my wifi isn't able to run consistently for more than an hour without suddenly dissconecting or slowing down completely to the point it's not usable. it worsens when i try to do something that isn't minimal usage such as calling or playing games, which it'll then just dissconect every few seconds/minutes. i've tried calling and testing my broadband over the phone and it says there's a problem with the set up, but when i test it on the app it says there's no problems at all. i'm paying for gigafast wifi that's supposed to be 900mbs but on my phone is only 400, and on my pc peaks at 170.
Re: wifi disconnecting
@clare152
No need for a second thread. Did you follow all the advice given to your first post? If you have, have you called Sky to report it?
Avatar for clare152
yea i've tried everything including the link i'd been sent from text message after i called. i haven't been able to get through to a real person since i don't have a landline phone though
@clare152
You do have a Sky Talk landline as it's bundled with your broadband package but you have chosen not to connect an actual handset which is fine.
If you buy a cheap handset in the future you only need to plug it in when you need to call Sky (by dialling 150 which is free) if there's an issue.
These are the current methods for contacting Sky, and some will be more appropriate than others …
🟧 📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you have Sky Broadband. The forum doesn’t allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
All calls will start automated (aka ‘the bot’) which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
🟧online help via this link
https://www.sky.com/help
🟧Sky Assistant 💬 should also be available via
🟧Social Media You can also get in touch via the messaging services on Facebook or Instagram, (links at the bottom of the forum page).
🟩Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
