Discussion topic: problem connecting my tablet to sky hub
This message was authored by: swinton+rlfc
Could someone talk me through from start to finish, from disabling the higher level of broadband and then how to add my device, then reenable the wifi, I am suffering with mental  health and find it hard to communicate, and the virtual service is upsetting me when I do get through to someone they say there is a fault but then the tech team say there is not
Re: problem connecting my tablet to sky hub
@swinton+rlfc What sky hub do you have, the white SR213 or the black SR203, the link below will show you what is what so click on that first. Once you confirm will link the page that is best for you to use and follow, it is a step by step guide!
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
@swinton+rlfc If you wish you can also just try this step by step guide that is linked below! Just take it slow and easy as you do it!
https://www.sky.com/help/articles/connect-devices-to-broadband-start
Avatar for swinton+rlfc
the white box
