Discussion topic: poor wifi signal
Message posted on 11 Apr 2025 10:35 AM
poor wifi signal
have checked connectivity, which is showing good. However, the signal is poor throughout the house, especially upstairs.
Message posted on 11 Apr 2025 10:52 AM
Re: poor wifi signal
@marsha13 Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
