Discussion topic: please help me urgent
Message posted on 17 Jun 2026 08:20 PM
please help me to check my broadband. its only got internet connect via lane cable direct. wiffi stop working and kick out all devide in my home . its urgent as all devide using wiffi. not cable accept 1 laptop
Message posted on 17 Jun 2026 08:27 PM
Re: please help me urgent
Your post isn't very clear but even if you’ve already tried it use this link to check if there are any issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
