Discussion topic: Wifi not connected
This message was authored by: mandy1657
Wifi not connected
I have run the tests but according to the results both broadband and WiFi are fine... Wifi is showing on my phone as "connected without internet"
Re: Wifi not connected
@mandy1657
Try rebooting your broadband hub at the mains, if this doesn't fix it then give this a try:
Try running this line test to see if it finds any faults:
Avatar for mandy1657
Done that. No help!
@mandy1657
What was the result of the line test ?
Also what lights are lit on the hub ?
