Discussion topic: password change for wifi
This message was authored by: KillAgh1-
I want to change my wifi password to something I can remember
Re: password change for wifi
@KillAgh1- changing youWiFi password is simple but varies according to ehich hub you have. On the white hubs dign into My Sky and go to the hub's settings in ofoduct options and simply click on the pencil icon.
On the black hubs type 192.168.0.1 into a browser when the hub interface loads click on WiFi and you will be asked to log-in use admin as the password and the WiFi password on the hub's label as the password.
When changing passwords remember to choose something you know but cannot be esily guessed by someone else as it is like the frontdoor to your home..
