Discussion topic: No or slow connection
Message posted on 10 Jan 2026 11:45 PM
Message posted on 11 Jan 2026 05:26 AM
Re: No or slow connection
@Tam09
See further down for guidance on hub lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
