8
This discussion topic has been answered Discussion topic: outage in Chesterfield again
This message was authored by: JustinAxe
Looks like it is BT as the pon light is red on the fibre box. Any explanation?
This message was authored by: cookiemonsteruk Answer
Re: outage in Chesterfield again
@JustinAxe
It may be localised as opposed to a widespread network issue . Give sky a call as above
@JustinAxe
There doesn't seem to be a widespread outage either with sky or Bt.  Give sky a call on 150 from your sky landline or sky mobile if not up by 08:00
Avatar for JustinAxe
The app says there is an outage.
@JustinAxe
This message was authored by: Dimsum
I encountered the same issue as you. The middle LED on the hub is red since 4am.
@Dimsum
I’ve tried all the steps, but no luck:(
It says :
There's an outage in your area
We're working on getting you back up and running. It usually takes a couple of days to fix things like this but might be sooner.
@Dimsum Standard generic message when there is a service supply issue to your connection, the fault may be up and repaired quickly or it may just take a longer time, it's all down to what has caused the problem!
@Dimsum
Once aware Sky usually quote 2 WORKING DAYS as a potential fix time due to the service level agreement in the UK between ISPs and Openreach for fixing a fault. Openreach claim to be successful within that timeframe in about 85% of cases.
Some repairs take longer, for example when a pole or cabinet has been damaged or Openreach / City Fibre need to dig the road up (after getting permission from the local council).
This link explains the Ofcom agreed auto compensation scheme which Sky operates for when there is a TOTAL loss of Sky Broadband or Sky Talk for UK customers.
https://www.sky.com/help/articles/auto-compensation
If you have a total loss of service and it isn’t fixed after two full WORKING days from when Sky are notified of the fault, you will become eligible for it.
From Ofcom’s website:~
If your broadband or landline service stops working, you will have to report the fault to your provider. If the service is not fixed after two full working days, you would not need to ask for compensation or contact your provider again, as your provider has systems in place that mean you will start receiving compensation automatically if the repair takes too long.
This auto compensation is applied 30 days after the fault has been repaired and will come in the form of a credit appearing on your Sky account (from 01/04/25 the rates are £9.98 for every complete day).
▫️There is no equivalent scheme in place for customers in the Republic of Ireland.
▫️There is no automatic compensation for TV services affected by a broadband problem.
▫️Sky broadband being discussed here is a domestic service therefore whilst it's fine for customers who work from home to use it for that purpose they won't receive additional or quicker support.
