1
This discussion topic has been answered Discussion topic: No internet but lan light on
This message was authored by: Browns77
Have a globe issue this morning - no internet but lan light on.  Can't connect to WiFi and it was mentioning captive portal errors
This message was authored by: JimM1 Answer
Re: No internet but lan light on
@Browns77 Just in case you need the link, lights is below!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
Then later this one....
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to be displayed by the software test! This should determine if there's an identified fault affecting multiple households.
