18 Mar 2023 12:36 AM
Activation was on the 17th and since then only power and Wi-Fi lights are green the internet light flashes Amber once in a wile like I will flash five times and maybe not for another hour or two
18 Mar 2023 05:47 AM
Posted by a Superuser, not a Sky employee. Find out moreSee if you can run this line test to see if a fault is found outside of your property and if something is found you can book an engineer repair.
You can also run this test via the MySky app.
Let us know how you get on.
18 Mar 2023 06:01 AM
All fixed now thanks
