Discussion topic: no mobile connection
This message was authored by: Trevor284
My sky router will not connect to some mobiles , I use the password but it says incorrect and does not connect
Re: no mobile connection
@Trevor284
If you are seeing an error about entering the wrong Wifi password then make sure you are not getting a 1 and l or a 0 and O muddled as it is quite easy to do this. It must also be entered as shown on the hub itself so use upper case letting if required.
