Discussion topic: Broadband security
This message was authored by: Laura_-
Broadband security
Having issues with all devices showing there is many in middle on broadband router . Switched on vpns as instructed . But does anyone have advice where to go or what to do?
Re: Broadband security
@Laura_-
Instructed by who?
Assuming you mean a 'man in the middle (MITM)' attack, the chances of actually being targeted by any such thing is extremely small.
Avatar for Laura_-
Level 0 icon
Hi, yeah man in middle attack . Was instructed by national cyber security. Then told to seek advice from broadband provider. Who keeps sending me to discussion board .
And how did the NCSC get involved?
https://www.ncsc.gov.uk/guidance/how-to-spot-scammers-claiming-to-be-from-the-ncsc
Avatar for Laura_-
Level 0 icon
Due to work devices that have a security system connected . Can you point me in direction of sky broadband security help ? Cause everything I tried send me back to sky community.
There's no such department which is directly accessible by subscribers.  You aren't going to get a general contact centre at this time of night, and I strongly suspect they wouldn't be any help at all.
I'd suggest you go through your employer's IT support mechanism.  Most likely it's a false alarm, but in the extremely small chance that it isn't they are going to want to know.
