Discussion topic: no interner
Message posted on 28 Jun 2025 07:49 AM
no interner
have no Internet
LOS light red on open reach hub
Message posted on 28 Jun 2025 07:52 AM
Re: no interner
@Amp5
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
