Discussion topic: myrouter.io
Message posted on 18 May 2025 10:20 AM
myrouter.io
When I try to access 192.168.0.1 which comes up as myrouter.io and which I understand from reading posts on here is fine, but Chrome doesn't want me to go there, so I can't log in.
Sky Max hub.
Message posted on 18 May 2025 10:23 AM
Re: myrouter.io
You need to use the MySky app to access your Max hub's settings:
https://www.sky.com/help/articles/change-wifi-max-hub-settings
Message posted on 18 May 2025 03:52 PM
Re: myrouter.io
Thank you. However, this only takes me to a limited number of options. I want to see the list of devices I have, and none of thise headings go there. I might want to change the channel...no option there.
Message posted on 18 May 2025 04:12 PM
Re: myrouter.io
@kajac Whatever the app allows you to do, then that is all that you can do.
Message posted on 18 May 2025 08:57 PM
Re: myrouter.io
Disable your vpn and try connecting to 192.168.0.1 again or try using a different device. Login with Admin as the username, and default wifi password.
FYI - Sky Max hub doesnt let you change much settings. Including Channel. Its automatic.
I've got an ongoing issue with it auto changing me to channel 149 which disables my 5ghz wifi connections.
