Discussion topic: Orange light on hub - no internet
Message posted on 13 May 2025 07:48 PM
For past 2 or 3 hours I have not had access to the internet. This has prevented my getting onto safari etc. I have done all of the checks, tried unplugging the hub and plugging back on. Have checked the connections. Are therr any outage issues currently?
Message posted on 13 May 2025 07:50 PM
Re: Orange light on hub - no internet
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Message posted on 18 May 2025 08:55 PM
Hi
Thanks for getting back to me. It appears the issue was one that was affecting quite a few others, sky Q box, the other day. So it seems to be working well now.
thanks for help.
