23 Nov 2024 12:36 PM
Hello some advice would be appreciated on adding a mesh network to my sky broadbanf at home.
Sky Broadband Superfast
Sky router: SR203
Having done some reading, I understand the basics but the detail is a bit complicated for me so looking for some advice.
I'm looking to improve the signal upstairs and extend to a garden room which is around 12 meters (and two walls) from the house.
Will the ASUS ZenWiFi XD5 AX3000 be sufffcient for this? Having done some reading I understand there is a possiblity that not all systems are compatible with sky broadband, is that the case?
Any help appreciated.
Faruk
23 Nov 2024 04:47 PM
If you used your sky router turn off the WiFi plug into the sky router that's what I have done with my eeros
