Discussion topic: issues with the service checker
This message was authored by: loverboi
anyone else had or having issues with the service checker online and the app and is it a sky end isse again as iv uninstalled and restarted phone and installed the app again and getting same issue with online/app ? 😞 😞
Service Checker
Pick a product for more help.
Sky Q
Help with Sky Q
WiFi
Looks good
Sky Broadband
See more info
Last checked: 6 minutes ago
Sky Mobile
Check your coverage
Sky TV apps
Check a
This message was authored by: mae-3
Re: issues with the service checker
@loverboi
Have you lost the service of broadband and the service app isn't reporting it?
Avatar for loverboi
Level 6 icon
service is working but i cant see everything is okay and running ok with my set up
Avatar for loverboi
Level 6 icon
@mae-3everything is working okay but the app not showing ect
@loverboi
Try removing the app from the device and reinstalling it from fresh to see whether that helps.
Avatar for loverboi
Level 6 icon
@mae-3  iv uninstalled and restarted phone and installed the app again and getting same issue with online/app ?
@loverboi
Contact Sky for support.
Avatar for loverboi
Level 6 icon
@mae-3thanks 🙂 😄
Avatar for loverboi
Level 6 icon
@mae-3 it started working about 21.00 last night ? 🙂 😄
