Discussion topic: internet up and down again.
Message posted on 19 Oct 2024 07:04 AM
internet service up and down since 6am
Message posted on 19 Oct 2024 08:08 AM
Re: internet up and down again.
@gab64 dint where yiu are but around me it is raining cats and dogs which can cause issues with broadband connections using old copper cabelling. Is that a possibility. If it is the iif tge problemi continues the DLM systems managing your connection will reduce speeds in steps eaxh night to stabilise the line Openreach rarely will acceot a fault unless line drops exceed 10 a day or the DLM systen drops speeds below the guarantee for your area.
Otherwise check for a loose cable if tgere is none and the service checker if that doesn't say there is known issue give Sky a call.
