Discussion topic: internet problem
This message was authored by: Sebastian1916
internet problem
Several times a week, there's no internet connection. There are two green and two orange LEDs, and when I run a test, it says everything is fine, even though there's no internet. I've also been without internet for about 30 minutes now.
Re: internet problem
@Sebastian1916
▪️I AM NOT A SKY EMPLOYEE ▪️
