Discussion topic: internet down, amber light, reset won't work
This message was authored by: lmpwan
the internet / wifi keeps going down, amber light showing on hub, we tried reset button and won't work.
Re: internet down, amber light, reset won't work
@lmpwan
First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
This message was authored by: Jay_92
Mine has been same since yesterday. I did a sky service check and it says everything is fine but it's not fine as non of my devices can connect to it
