Discussion topic: internet amber light
This message was authored by: liyana
Hi i dont know why my broadband has a problem. The internet light is amber instead of green. the power and wireless button is all green. tried restart so many times and turn off the power on off. nothing changes. it is also my housemate account so I cannot do anything as I dont hold the account.
Re: internet amber light
@liyana
If the broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
As you're not the account holder, so long as you know the telephone password you should be able to report it to Sky.
