Discussion topic: WiFi
Message posted on 06 Aug 2025 09:05 AM
WiFi
WiFi keeps dropping out with the middle light on the router going to orange
Tried disconnecting the dsl at each end as suggested but has made no difference
Also My Sky isn't working
Message posted on 06 Aug 2025 09:47 AM
Re: WiFi
I've had this issue for 2 days now too
Message posted on 06 Aug 2025 10:39 AM
Re: WiFi
@JML1961 @LadyRachel Have either off you called sky, or tried running the remote diagnostic tool just incase there is a specific fault or condition that Sky may or may not be aware off. Links are below should you need them!
Try running the line test here to see if any faults are found:
