Discussion topic: intermittent broadband
Message posted on 18 Feb 2026 09:15 AM
I'm on etehrnet not wifi. When my signal is good there's no speed issues but I get intermittent pauses. It could be nothing for a day--then next day i loose broadband for 2 mins, then later 3 mins, then later 2 mins etc. It's happening randomly i can't see a pattern. I have rebooted my mac and router multiple times. This has been going on for weeks. There's no known disruption from sky in my area. The physical cable is fine. If i switch to wifi the problem is similar. it makes working and zoom calls very difficult. Any ideas?
Message posted on 18 Feb 2026 09:28 AM
Re: intermittent broadband
@mbakowski What sky hub are you using? sound's like you have a connection issue with either the sky Hub to the BB connection disappearing for short times as you say it's both Ethernet or wireless wifi affected....
The boot sequence on a sky hub is from 3 minutes to 5 minutes time wise, but you can see that by looking at the Hub light's.....
Message posted on 18 Feb 2026 12:16 PM
thanks for responding--it's a 'sky max hub' ---so if the sky hub is losing connection to BB what can i do? is it a sky engineer thing? It seems very hard to contact them to talk aboutthe issue!
Message posted on 18 Feb 2026 12:20 PM
@mbakowski Just dial 150 from your sky Talk landline connection, you will have to fight the BOT but that is by far the easiest way to talk to a sky Customer Service Agent!
Message posted on 18 Feb 2026 12:25 PM
thank you very much!
