Discussion topic: hub
This message was authored by: JayG69
hub
We're going from copper to full fiber next month. We've recived the "converstion cabel" but that uses one of the ports on th router and I already use all 4.Any suggestions?
Re: hub
@JayG69
You'd need something like an unmanaged 8 port ethernet switch
Re: hub
@JayG69
Using the WAN ethernet port (#4) for connection to the ONT isn't optional, so as @cookiemonsteruk indicates, you'd need to expand the capacity for other devices with a switch.
