15
This discussion topic has been answered Discussion topic: how do I connect my router
This message was authored by: yerweepal
I have just signed up for sky. Is the hub just plugged into a mains socket and that is it?
This message was authored by: cookiemonsteruk Answer
Re: how do I connect my router
@yerweepal
Now you are only missing an ethernet cable..  Just sit back and relax and just post here closer to the time if there are any further issues.
P.S.  glad you sorted that bit about the 12GB cap. 👍
@yerweepal
What package have you opted for
Superfast fttc requires a openreach mastersocket
Ultrafast fttp requires an ont. If you don't have one is will be installed on the day of activation
Avatar for yerweepal
Level 2 icon
I have opted for ultrafast+ 500
@yerweepal
When is you activation date?
Has this ont been installed
Level 2 icon
I will also have hub 4.2 supplied
@yerweepal
Have you received a conversion kit ethernet cable? This will connect from lan 4 on the sky hub to the ont when installed
Again when is your activation date?
Level 2 icon
I have not had an ONT fitted, and no mention has been made of it. Activation date is 25/ 3/24. It is a 4.2 hub
@yerweepal
Thats a long wait . The ont pictured above will be the last thing to be installed by openreach.  After which they contact sky to activate you
Level 2 icon
I have not had a conversion kit supplied for activation on 25/march/24
Level 2 icon
The wait was my choice and no mention has been made so far
@yerweepal
Thats strange the hub is sent out usually to be with you the day before activation.  The conversion kit is usually the first.  Enter your full address below in the link and post the notes under the table
@yerweepal
Ah, if it was your choice little posting the info. That would only give info relating to issues on openreach end 👍
Level 2 icon
I am sorry, I do not fully understand this answer. Is there possibly some spelling mistakes
@yerweepal
Meant to say theres little point posting the info requested from the link as that only applies to delays from openreach
Level 2 icon
I do have an ONT box, which was fitted when I actually had BT internet
