Discussion topic: help
This message was authored by chris878 This message was authored by: chris878
help
When I set up my Tp link vr2800 it auto selects AnnexA/L.
Why does it select Annex L? I am on fttc.
Re: help
@chris878
Can you post your hub stats
https://community.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/m-p/2855717#M1014...
Annexe L is extended range adsl that allows for ranges of up to 7km from the exchange
Re: help
@chris878
After checking stats from a previous post i would reckon tp link is auto detecting a combination of annexes that includes A which is the one openreach sync up on and L would be redundant
chris878
Re: help
I have a vr400 tp link router. I connected this up, and it dident use Annex L in its dsl settings. It only used Annex A.
On top of that I noticed slightly faster uplaod and download speeds.
But this router has NAT acceleration enabled by default. If I disable it speeds return similar to that of the vr2800!.
So I am not sure which router is more compatible with openreach.
I think I might just go and buy a Draytek router instead, because it says on the specifications it is openreach supported.
Re: help
@chris878
The modem side of each hub should be exactly the same.
chris878
Re: help
seems that NAT acceleration speed up the broadband speed.
Re: help
By cutting down on cpu usage rather than anything related to the modem or annexe. How fast is the vr400 with nat acceleration in comparison to the vr2800 .  It appears to be more beneficial to speeds over 100Mbps which openreach doesn't support on vdsl lines
Re: help
@chris878
More about NAT acceleration
https://www.speedguide.net/faq/what-is-nat-acceleration-495#:~:text=NAT%20Acceleration%20is%20a%20se....
