Discussion topic: Apple Airplay wired v wifi
This message was authored by ReiRahamans This message was authored by: ReiRahamans
Hi there,
I want to airplay my mac to my Samsung TV. However we use Virgin broadband and have ethernet in the house into the back of TVs. So the TV is on ethernet wired with a Sky wifi name. I need to be on the same network to airplay but I dont know the password for this sky network that has been created amongst the TVs.
Anyone know how I can get the TVs Sky password? Thanks
Re: Apple Airplay wired v wifi
When Sky isn't the ISP, the credentials in use by Q hardware to communicate with each other is not information which is available (it's encoded in the WPS exchange which links the Q hardware elements to each other).  This shouldn't affect the Samsung TV though: that will have a network configuration assigned by the Virgin Hub.
ReiRahamans
Thanks for that answer. So I cant get my laptop onto that Sky network? I can see it, I just need the password. Of course I can switch TV from wired to wireless each time but thats a pain
This message was authored by Eeeps This message was authored by: Eeeps
@ReiRahamans wrote:
Hi there,
How is your Mac connected to your VM broadband?
If your Mac connecteds to your VM hub (either wired to wireless) and the TV is connected via ethernet this should work.
In your description, I don't understand your comment "the TV is on ethernet wired with a Sky wifi name". If your TV is wired to the VM Hub via ethernet then it does not need (or use) a WiFi.connection?
ReiRahamans
Sorry I meant the TV is connected via a Sky network name. And my mac can see that network in the wifis, but I cant connect to it because I dont have the password. For airplay to work, TV and mac need to be on same network (it says same wifi network, but I assume TV wired and mac wifi would be fine)
@ReiRahamansYes that would work as long as they are on the same network, that is connected to the same router.
I don't see why the television itself would be.  You could try a network reset on it.
