Discussion topic: hP printer 6600 saying printer settings inconsistent with wireless
This message was authored by: Ally18
Message posted on 25 Jul 2025 02:57 PM
Please can someone help. I am trying to connect HP6600 with wireless network. It is saying it cannot connect MAC address filtering enabled.
Do you know how I can enter a MAC address. ?
thank you
Find out more
Message posted on 25 Jul 2025 06:20 PM
Re: hP printer 6600 saying printer settings inconsistent with wireless
A Sky Hub doesn't do MAC filtering by default.
With a white Max Hub you may need to reduce the wireless security level from WPA3 to WPA2-PSK using the Hub settings in the My Sky app.
You can use the same settings to temporarily disable the 5Ghz WiFi band: remember to re-enable it afterwards if you do this.
