Discussion topic: fiber install
This message was authored by aw1000 This message was authored by: aw1000
fiber install
i am just about to make an upgrade to fiber with sky -do any extra boxes need to be installed - my neighbour has had an extra box installed outside his house through jurassic fiber- but i can see no mention of this on sky's info
Re: fiber install
@aw1000 Sky only offer services over Openreach's network they dont use any of the smaller Altnet networks like Jurrasic Fibre unfortunately.
aw1000
Re: fiber install
ok thanks for the reply - but do BT openreach need to install another box ?
Re: fiber install
@aw1000
It depends what upgrade you are doing with Sky. If you are upgrading from Superfast to Ultrafast then the likelihood is that Openreach will come and install the fibre line to your house which will result in a small box on the outside of your home where the cable comes in and then a white box on the interior where it feeds into an ONT which then connects to your router
I am NOT a Sky Employee
Re: fiber install
@aw1000
In Openreach terminology the external box is the 'Customer Splice Point'*: this houses spare length on the four-core optical drop cable, one core of which is fusion spliced to the fibre pigtail that is brought inside the property.  The CSP is typically as near as possible to the duct or pole bringing the fibre to the address, but may be some distance from the entry point into the building.
*Sometimes Customer Service Point.
Re: fiber install
 @aw1000 first question should be do Openreach have fibre in your road its not a given they have as only around a third of addresses have been passed so far?
You can check by using the checker here https://www.broadbandchecker.btwholesale.com/#/ADSL/AddressHome by entering your full address you are looking for a line mentioning FTTP (not FTTP on demand which is different) and then over to the right what it says under FTTP Install Process. If you post the result obscure your address details.
aw1000
Re: fiber install
@Chrisee fiber was all installed in the street about a week ago, but i have been given so much mis infomation about installation and what the process is - but it is much clearer thanks to the info given on here
