Discussion topic: does the purple cord come with your sky box to connect your phone i was with BT
This message was authored by lady+kimmy This message was authored by: lady+kimmy
i cant ring out or get calls on my land line
it is an old BT phone
do i still plug th purple lead into the wall and my sky box
even though that was also a BT conection
Re: does the purple cord come with your sky box to connect your phone i was with BT
@lady+kimmy it depends as these days the landline can either use traditional phone sockets or plug into your Sky hub. If you have the newer vertical type of Sky hub which has 4 green leds on its front your phone. Plugs into the hub. If you have the older flat type of Sky hub or the vertical type without the fourth led lit then use your phone sovkets.
