Discussion topic: connecting to chromecast
This message was authored by: b86
I cannot connect to my chromecast and there is a message saying I need to disable the access point or client isolation by logging into the sky hub ip page. however I cannot get logged in as it is telling me my login details are incorrect. what is the user name? I think I have the password correct
Re: connecting to chromecast
@b86  The usermane to login on the router admin page is always " admin " without the quotes.
Avatar for b86
I have used admin and the password that I have been provided with but I am still unable to login
@b86  Which router do you have from Sky in the link below.
Avatar for b86
sky broadband
@b86  So this hub that you have this for a long time and how many years?
Avatar for b86
just got it installed today
@b86  What lights are showing on the hub if this is your activation date then it can take up to midnight for the data to flow.
Avatar for b86
3 solid green lights
@b86  What are they named and any that are not on at all?
Avatar for b86
power, Internet, WiFi  are all solid green and voice is off
@b86  If that is correct then you should have internet and check with the sticker on the back and the card that come with the router that you have put in the WiFi password correctly.
Avatar for b86
I do have Internet but from what I can gather there is something called the ap client router mode which is enabled and that's stopping the chromecast from working correctly
