Discussion topic: broadband slow
Message posted on 26 May 2025 12:43 PM
broadband slow
I have been haveing trouble with my speed for a while, I had a message saying I could leave sky without a penalty. when i phoned I was tol there is no problem with the speed. I checked again and it was back to 51g. but latelyit has gone back to 20. yet they messaged everything wwas fine. getting fed up now.
Message posted on 26 May 2025 01:02 PM - last edited: 26 May 2025 01:03 PM
Re: broadband slow
@Maltwigg199 What sky router do you have, link below to get the router stat's, have a look and if applies post your's up.
Message posted on 26 May 2025 01:10 PM
Re: broadband slow
Hi I have a sky max router.
Message posted on 26 May 2025 01:26 PM - last edited: 26 May 2025 01:28 PM
Re: broadband slow
@Maltwigg199 Thanks for the reply, you may not be able to get stat's info from it as all app driven, was trying to see if you had a potential line issue, See the link below about lights, you have posted a few times now speed related so trying to see if any help for you. Will go take a look at your posting history.
Are you also on a copper fttc connection with the sky Max hub, ie it is plugged into an OR Master phone socket?
Message posted on 26 May 2025 01:32 PM
Re: broadband slow
Thanks Jim, I cant get into tech stuff sorry, im 80 year old and slow at picking things up, Thanks for your help, I will phone sky,
Message posted on 26 May 2025 01:35 PM
Re: broadband slow
@Maltwigg199 No problem, best way to do it, nothing worse than an intermittent fault that comes and goes....
