Discussion topic: broadband router
This message was authored by: gplanner
broadband router
I've had 3 sky broadband routers on the last few weeksbecause of slow speed (half of expected).They start off fine then all then dropi. What's the problem and how do I fix it?
Re: broadband router
Presumably not the router...
@gplanner Depending on your package you may be able to have sky send an Engineer to take a look to see what is going on with your connection. Give them a call, dial 150 from your landline!
