Discussion topic: broadband router help
Message posted on 07 Jul 2024 10:14 AM
Hi I recently got my broadband installed it's full fibre and it enters the property through my living room, that's where the box is fixed to my wall and where the router is placed, I was told it is the newest hub ( the white one). My problem is that it is too far away from my ring
door bell, so can I moved the router into my hall and get a longer cable that connects router to box on the wall, also is it a different type of cable as I see it goes into the port marked WAN on the router or would standard Ethernet cable be fine, thanks for any help given
Message posted on 08 Jul 2024 11:06 AM
Re: broadband router help
@Lee1234554321 Could use power line adapters thus saving you having long cables within the property,
