Discussion topic: Broadband not connecting for long enough
Message posted on 08 Jul 2024 10:38 AM
Message posted on 08 Jul 2024 10:48 AM
Re: Broadband not connecting for long enough
@Keeleyrose If you are talking about the green light on the far-right hand side of the ONT this is supposed to happen showing that data is flowing. Do you have any dead zpnes in the flat that other devices find it hard to connect using the Wi-Fi?
Message posted on 08 Jul 2024 10:56 AM
Message posted on 08 Jul 2024 10:57 AM
Message posted on 08 Jul 2024 10:58 AM
@Keeleyrose Does the likes of your mobile phone loose the Wi-Fi while in the same room as the device you are having problems connecting to the Wi-Fi?
Message posted on 08 Jul 2024 11:01 AM
Message posted on 08 Jul 2024 11:04 AM
@Keeleyrose There are a few ways around this you can either get a Wi-Fi extender or use powerline adapters to connect the device and you can then use ethernet in the latter to cut out the use of the Wi-Fi.
Message posted on 08 Jul 2024 11:06 AM
Message posted on 08 Jul 2024 11:07 AM
@Keeleyrose If you know the ethernet way then powerline adapters would be better for you.
Message posted on 08 Jul 2024 11:08 AM
