Discussion topic: Wrong password
Message posted on 07 May 2025 02:54 PM
Wrong password
Hi, I’ve just set up my new Sky broadband router. I can see the WiFi name on my phone, but every time I enter the password (as printed on the back of the router), it says it’s incorrect. I haven’t changed anything, and the router is brand new. Could you please help me connect?
Message posted on 07 May 2025 02:56 PM
Re: Wrong password
Message posted on 07 May 2025 03:18 PM
Re: Wrong password
Hi @Ehab2
Are you sure you are typing it correctly? A lot of the default passwords on Sky hubs use numbers that look like letters and vice versa. Also make sure you using caps/lowercase correctly as they are case sensitive.
Message posted on 07 May 2025 03:19 PM
Re: Wrong password
I am sure I typed it correctly
Message posted on 07 May 2025 03:22 PM
Re: Wrong password
In that case I would try a full reset of the hub. Hold the reset button on the rear of the hub for a minimum of 30 seconds
Message posted on 07 May 2025 03:27 PM
Re: Wrong password
I hold reset button for 30 seconds then what
Message posted on 07 May 2025 03:34 PM
Re: Wrong password
Try the password again
Message posted on 07 May 2025 03:46 PM
Re: Wrong password
I tried the password butt still not working give wrong password
Message posted on 07 May 2025 03:48 PM
Re: Wrong password
Message posted on 07 May 2025 03:49 PM
Re: Wrong password
Message posted on 07 May 2025 03:50 PM
Re: Wrong password
Message posted on 07 May 2025 03:51 PM
Re: Wrong password
Afraid you may need to contact Sky and get a new hub sent out then
Message posted on 07 May 2025 04:18 PM - last edited: 07 May 2025 04:20 PM
Re: Wrong password
@Ehab2 The label on the back off the hub with the Wi-Fi network name, is that the same as yo see on your connecting device to the back off the hub. If so the password as you see it Uppercase Lowercase EXACTLY as you read it put that in... Watch out for the i / 1 & l / L they can be hard to see, Magnifying glass if it is 2 small, write it down on a piece off paper.....
https://www.sky.com/help/articles/find-and-change-your-wireless-password
Message posted on 07 May 2025 04:20 PM
Re: Wrong password
Same name and the add word on back of hup
i am sure about entering the password
Message posted on 07 May 2025 04:25 PM
Re: Wrong password
@Ehab2 Is it just your phone that has the issue?
