Discussion topic: Wrong address on Openreach
This message was authored by: Matt25
Openreach has both the correct and an incorrect address listed on their system, with the correct address not having any connection listed, and the incorrect address having connections available. From what I can see online the current provider has to request to have this changed. Is it possible to get this fixed?
Re: Wrong address on Openreach
@Matt25 errors on the Openreach database do turn up from time to time while you can ask an ISP to correct these many including Sky seem unable to do do reliably. The actions Sky agents can take are dictated by their IT set up so if the option isnt on their screens it can be difficult to get the request escalated to someone at Skywho can. BT/EE do seem the best at getting these things sorted to be honest.
