Discussion topic: Working From home, Broadband keeps dropping out
Message posted on 14 Apr 2026 10:31 AM
I work from home and usually have no problems. Over the last week my Broadband stops working several times a day. I have gone through all the steps Sky offers and they all of them tells me it is working fine even when my devices won't connect to the Internet.
Message posted on 14 Apr 2026 10:35 AM
Re: Working From home, Broadband keeps dropping out
@Gooders-AG
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
