Discussion topic: Work VPN
Message posted on 25 Apr 2025 03:28 PM
							Work VPN
Good afternoon hope you are able to assist 🙂
I have recently needed to connect my work laptop from home through a VPN (Cisco)
When logging on to my work applications sometimes the connection is fine and works - other times it doesn't.
I also have a sky mini box in the office which the VPN also interrupts when not working
My IT department have suggested the VPN is being blocked by sky - Sky are suggesting the issue solely lies with the VPN (of which I have no option not to use for work purposes) and so I am in limbo somewhat!
Any advice you may have would be greatly appreciated
many thanks
Ben
Message posted on 25 Apr 2025 03:36 PM
							Re: Work VPN
@BenAndFiona Are you new to Sky and what colour is your Sky router that you have?
Message posted on 25 Apr 2025 03:38 PM
							Re: Work VPN
Hi thanks for getting back to me.
We have been with sky for 3 years now and have a black router.
All was fine until a few months ago when I had to start using a VPN for work
