Discussion topic: Work VPN BLOCKED suddenly
Message posted on 24 Apr 2025 05:33 PM
I've had sky years but they've suddenly started blocking my work VPN I work from home only due to disability. Works IT dept installed a new VPN that worked for about two months then stopped then they installed another one now that's not working. Work have tried everything and said the issues with my sky router blocking the VPNand other than come in the office there's nothing they can do.
I've turned off shield and I followed some steps suggested on sky website this still hasnt worked.
Im tearing my hair out and going in circles I cant even find a number to call Sky IT department.
can anyone help please.
Message posted on 24 Apr 2025 05:37 PM
Re: Work VPN BLOCKED suddenly
@VickyWS You can contact Sky by phone by dialling 150 if Sky is your phone provider or by following the link below
https://www.sky.com/help/home
scroll down to need more help click on this and you will find a phone number. If you are in ROI please change the flag at the bottom right to the ROI flag
