4
This discussion topic has been answered Discussion topic: fibre upgrade - what should be delivered?
This message was authored by: Toshi1979
Hi, I'm upgrading to full fibre and had a delivery today for a conversion kit. What should be in it, it wasn't what I expected.
This message was authored by: peter-marlow+1966 Answer
Re: fibre upgrade - what should be delivered?
What you have been sent is all the engineer  needs for the full fibre  installation, I  had sky full fibre broadband  900mps  fitted  in January  of last year  and in the December  i got the same  kit
P c marlow
@Toshi1979
Apart from openreach installing an ont the only other thing you may receive is a new router depending on what router you have now and what speed you have opted for
@Toshi1979
The Sky 'conversion kit' is just an ethernet cable: this goes between the Openreach ONT (which may still be due for installation) and an existing SR203 Sky Broadband Hub.
Avatar for Toshi1979
Perfect, thanks - that's what I got. The order mentioned a new router and that's what I was expecting, thanks for confirming for me.
P c marlow
