Discussion topic: Wireless
Message posted on 28 Apr 2026 08:25 AM
Wireless
Message posted on 28 Apr 2026 08:27 AM
Re: Wireless
@Milnie sounds like poor WiFi signal. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
