Discussion topic: WiFi keeps disconnecting
This message was authored by: TheChineseWurzel
Since my broadband was upgraded to full fibre, my router is struggling to connect to certain devices, mainly mobile phones and my work laptop.  Repeatedly asks me to input password and the. Connection lasts a couple of minutes before disconnecting again.  Ran tests and says there are no issues in the area or my hub.  Any ideas?
Re: WiFi keeps disconnecting
@TheChineseWurzel
Try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
Avatar for TheChineseWurzel
Thanks for this @caesarome
I've already tried both of these and still having issues.  Even moved the booster closer
