Discussion topic: Wifi
This message was authored by: Karendaily
Wifi
All lights green not working won't accept password
Re: Wifi
@Karendaily
If you are seeing an error about entering the wrong Wifi password then make sure you are not getting a 1 and l or a 0 and O muddled as it is quite easy to do this. It must also be entered as shown on the hub itself so use upper case letting if required.
