Discussion topic: Hub failing
This message was authored by: RoadkillAndi
Message posted on 14 May 2026 11:39 AM
Hub failing
My old Sky Q hub keeps failing and dropping Wifi, plus none of the LED lights work properly. Constantly need to rest it. Checked Openbox connection from the internal test port and all good. Will Sky replce the hub? It must be a few years old at least
Find out more
Message posted on 14 May 2026 11:42 AM
Re: Hub failing
Yes. Sky are actively replacing Sky Q hubs as they no longer receive security updates. Mine was changed February 2024.
Find out more
Message posted on 14 May 2026 01:26 PM
Re: Hub failing
This is the link to order a free replacement hub:
